New to the forum
haybale
lemmon sd
351
3" body
Hello all, Just joined this forum. I've looking at for some time as i'm in the process of swapping a V8 into 97 4x4 Ford Ranger. So far i have gathered a 351W, a c5 from a broncoII and a 3" body lift. I have found many helpful topics on here and will be looking for more info/ options for wiring the carberated engine into the 97 body. Thanks.
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
8,370
Welcome to TRS :)
Good page to bookmark here: https://www.therangerstation.com/tech_library/index.shtml
Check out Engine section and Conversion section for V8 swap Ranger info
Not much engine wiring needed for carb/distributor systems
12v key on, for spark
Oil pressure wire
Temp sender wire
Tach wire(optional)
Need a 12v key on for alternator, this wire comes from Battery light in dash, light green wire on current alternator, can't be used for spark
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Shadowrider6661
D RANGED
ASE Certified Tech
129
Off grid Northern Arizona.
Stock
4"
N/A
33 x 12.50 x 15
Drive it, Break it, Fix it, REPEAT !
Welcome to TRS, there's no place like it.
ericbphoto
16,598
Wellford, SC
6"
haybale
lemmon sd
351
3" body
Welcome to TRS :)
Oil pressure wire
Temp sender wire
Tach wire(optional)
thanks. i found quiet a bit of info there.
Elutheros
129
Central Texas
Welcome! I dream of building a 351 but it's going to remain a dream!
