New 4.2L FWD motor to 3L auto Ranger?
TomB1269
Capital District NY
2002, 2005, & 2
All Fords
3.0L/4.2L/5.4L3V
The 4.2L in my Freestar looks to be the same block as the 3.8L in my old Windstar. If ever the opporunity arises would the 4.2L FWD fit as does the old 3.8L FWD? If you have driven the new F-stars, the HP is only around 200 but the torque is nice at 268 and the curve is 3600 to 4200 rpm. Which makes it a very nice driving engine for the weight van is slightly heaver than 2002 Edge extra cab 2 door. :icon_confused:
rurouni20xx
natchitoches, la
3.0L V6
since a 4.2 is simply a stroked 3.8 i think it would be nice, the question is are the bolt patterns the same. til somebody takes one out and confirms its a 3.0 pattern not a 5.0 pattern i dont think anybody will attempt it.
Piper106
According to one of the websites that talks about Ford trans bolt patterns, the FWD 3.8 / 4.2 L V6 motors have the same trans bolt pattern as the Ranger 3.0 V6.
That is what I have read, I have not seen the parts in question, so proceed with caution.
Piper106
Moto Mel
Va. Bch., Va.
1994
19
Li
Piper106
The bolt pattern is also the same between the 3.8 V6 and the 4.6 V8 which gives a multitude of engine swap choices.
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
The 3.8L V6 in a Rear Wheel drive application will share the same bellhousing bolt pattern as the modular mustang V8s. The 3.8L V6 found in front wheel drive (trans-axle) applications will share the same bellhousing bolt pattern as the vulcan 3.0L V6. In order to bolt a 3.8L/4.2L V6 to the 3.0L vulcan's transmission, you would need to find one out of a FWD vehicle.
Dave
southern New Jersey
3L
Doesn't a RWD 3.8L have a SBF bellhousing? Or did Ford make the RWD 3.8L in both SBF and Modular bellhousings.
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
Not all the 3.8's have a Winsor bellhousing.
I can tell you for certain that the manual trans I have out of a Thunderbird Supercoop is most definatly NOT a windsor bellhousing.
I got the trans in the hope of using it to make a 2wd 5.0 Ranger
without using a cable clutch or an "R2" F-series transmission.
That hope died as soon as I had the trans next to the 5.0 engine
I had at the time.
AD
Faster7
Missouri
I had at the time.
AD
:icon_confused: Can you send pictures of that transmission? I've been around supercoupes and other IRS thunderbirds for years, and every 3.8 car has has had the windsor bellhousing. Same thing with my '82 grenada 3.8 V6 and the early fox 3.8's I've worked on.
DCinDC
20
Northern VA
The 4.2 fwd will be my upgrade path when my 3.0 dies, which is unlikely cuz I have a dizzy.
Hey Allan! :wave:
odie1969
Firefighter
EMT / Paramedic
tempe Az
4.0l sohc
OK let me get this I can take the 4.6 out of the wifes Muff-stang and drop it in the ranger with out swapping the trans. Ya that will last a week before the trans is in peices. But I wish someone would do the a 4.2 swap. that might be a cool swap with good info.
351crownvic
Geneva on the take, Ohio
3.8 rwd is sbf.... fwd 3.8s have the 3.0 bolt patern... FWD is stamped on the side of the block in big letters.. early early early 4.6s like some 92's had the sbf bellhousing pattern. its a rare find..
B24FREE
Peoria?Bartonville IL.
FORD
I had at the time.
AD
Well I think you got the wrong tranny!!! I saved the AOD when I parted out my 1990 thunderbird supercoupe and I used that exact tranny in my 5.0 ranger for a year till I did the T-5 swap. I also swapped the supercoupe 3.8 into my 1990 mustang and used a regular 5.0 mustang t-5 tranny. The RWD 3.8 has the windsor bolt pattern. I could post some pix if needbe. I forget the name of the supercoupe tranny ,but it is not a T-5 and the shifter would be farther back than the T-5.
gwaii
2010 OTOTY Winner
2010 Truck of The Year
66
haida gwaii
460
don't know about the fwd crap,but when i pulled the 3.8 from a 94 mustang to replace it with a built 351w i just bolted it up to the stock t5-worked great,even if it was a little squirly.
boisdarcpost
Texas
3.0 l
I have a nice 94 XLT with 3.0 L V6. As it now has over 140,000 miles, I am considering swapping in a 4.2 V6 & AOD from a 97 or later F150. This seems like it would be the perfect combo for the Ranger. My truck has a 4 inch body lift, so clearance should be no problem. My main concerns relate to the electronics. It would be just a street machine. Has anyone out there done this swap.
myold96
pinecity/rosaila washington
2.3l
engine swap
would the 5spd out of a 96 ranger 2wd bolt up to a 3.8lengine out of a 95 windstar?:dunno:
