Neutral Balanced 5.0l flexplate flywheel
spock1996
Minnesota
1995 5.0L-354 stroker
I have a 1995 5.0l that has been stroked to a 354ci, it was all balance to neutral with a neutral balancer and a aod flexplate with the weight removed. I now want put a manual in it and I think a i-6 300 flywheel will bolt up and is neutral balanced but since the aod flexplate has a big hole opposite of where the weight was does that mean its not quite neutral? what do I need to do here?
baddad457
18
Opelousas La.
The six flywheel should work. As for that missing metal, ask the guy who balanced your engine.
spock1996
Minnesota
is what im gettin at is instead of using neutral flexplate when it got balanced, he took the weight off the aod flexplate and ford puts a hole opposite of the weight I guess to get by with a smaller weigh, the neutral flexplates are solid, would the weight of that hole be enough to affect the balance if I put on a true neutral flywheel?
baddad457
18
Opelousas La.
No engine is perfectly balanced at all rpms. The guy who does the balancing on my engines told me that. He'll balance one for a certain rpm range. That missing metal likely wasn't enough to make a difference, if you never felt it in running the engine, then you're fine.
spock1996
Minnesota
I haven't put the new flywheel on yet, I wanted to get other people's input before I did it
spock1996
Minnesota
Top picture is stock flexplate with weight, bottom is a neutral.
spock1996
Minnesota
I did find a flywheel on summit racing web site that says it works for 240 300 5.0 5.8 internal balance
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
