rekles
- Mar 4, 2015
- Reaction score
- 3
- Location
- lake havasu
- Make / Model
- Ranger
- Engine Size
- 4.0 ohv, 4.0sohv
- Manual
Hello,
I have a project that has been put on the back burner a few time but now I'm ready to wrap it up and I want to drive my truck finally.
The truck is a 1999 xlt ranger 4.0 ohv, I started off with a blown head gasket 2 months after I bought it. I was about to do the head gaskets but when I took the heads off I quickly found out that both heads are junk. Without enough cash to get new heads the truck sat. When I came up with the cash for the heads I was advised to overhaul the entire engine due to hi mileage 220k.
So the truck sat for awhile.
I came across a 4x4 02 xlt with a sohc 4.0 that had been flipped over but was running perfectly so I began the swap.
First thing i did was all 3 timing chains, bought the kit with all the tools to do it from Ebay.
Swapped almost everything over but the diner car but got a complete different interior from a 01-03?
Also replaced alot of parts.
*new water pump
*new radiator hoses
*new spark plugs
*new spark plug wires
*new filters ( fuel,oil,air)
*new fuel pump (2002)
*new battery
The problem I am having is it wont run. I turn after it has sat for a while and starts then dies immediately.
I have checked the spark with a cheap spark plug light hat has a clamp on it and it lights up on all cylinders.
I also know it is getting gas to the fuel rail because I purged the valve.
I think I have it narrowed down to a few things
(1) timing is off
I admit this is my first time doing a sohc timing chain but I took my time and followed every direction to a T and used the required tools specifically for the job. Also wouldn't it still run if I was off on the timing off a little? Would it still start and die if the timing was off?
(2) Pars system or ecm?
I did swap over a complete new interior witch included a new gauge cluster. Would that make a difference? I did swap over the ignition with matching chip to computer so that is a match. Any way I could test the ecm and see if its throwing up a Pat's issue?
The theft light stays on for a few seconds then shuts off like it should also no check engine light.
I did have a mechanic plug in a snap on tester to it and he did a diagnostic check witch went through all the sensors to see if they were working properly and they were.
I swapped out both the crank angle sensor and coil from a running sohc and same issue. Also deleted the inertia switch and wired both wires together.
Maybe the evap lines need to be swapped ? I'm at a loss Andy help so I can save some cash would be great.
*new water pump
*new radiator hoses
*new spark plugs
*new battery
(1) timing is off
