rangertodd
- Nov 2, 2007
- 0
Does the 3.0 liter engine in a '99 Ranger have a voltage regulator seperate from the alternator, or is it all one unit?
Details:
I've got a voltage issue with my '99 3.0 2wd Ranger. Sometimes when I start it up the battery light comes on and the voltage reads very low on the volt gauge. It doesn't seem to cause any drivability problems, but the lights and other electrical equipment deifinitely doesn't get enough juice.
My first impression was that it was an alternator issue, but after a few miles the volt gauge snapped back to where it normally sits , the battery light turned off, and all the lights, wipers, etc. went back to normal. The next day the same thing happened.
However, the following day the opposite happened. The voltage spiked for a few minutes, then went back to normal. This happened twice on my 5 mile commute to work that day. Now today it's reading low voltage all day long. I called the auto parts store for a voltage regulator, but they didn't have one listed for the 3.0. Is it inside the alternator in the '99 model, or is the regulator for the 4.0 (the one they DID have listed) the same as for the 3-liter? It definitely seems like a regulator problem to me, but are there any other options I should investigate?
Details:
