Planetpluto718
- Oct 17, 2014
- 0
- Ford
- Engine Size
- 4.0
Hello everyone!
I've of course got a problem with my Ranger, and can't seem to figure it out!
First off I am not getting a MIL, and am sure the lamp functions properly. When I start the truck, it runs just fine, if not for a slight idle issue. At idle the engine seems to rev up and down, but not much, maybe at a range of 100rpm difference. I can put the truck in gear and take off down the road and it drives perfectly. But within a short period of time, one to five minutes, it starts running very rough! Engine acts like it wants to stall, almost like it's starving for fuel, and pressing the gas pedal does absolutely nothing, but the engine doesn't cut off. It just lopes along erratically for a short bit, and then seems to "jump" back into running correctly. This will occur randomly and does not seem to be affected by engine temp, outside temp, or any other variables that I can think of. It also will do the same thing at idle. If I start truck and just let it idle it runs great for a few minutes, then exhibits same symptoms for a short bit, and then jumps back to running normally. I was getting a MIL and decided to do a tune up and replace some things, after that I don't get the lamp on any longer, but truck still runs terrible. Here's what I've done so far, and thanks for any input on this issue!
1994 Ranger 4.0 2WD Extended Cab
New parts include -
Mass Air Flow Sensor
Plugs
Wires
Electronic Coil Pack
Fuel Pressure Regulator
Idle Air Control
Both O2 Sensors
Vacuum lines replaced
Brake Booster / Master Cylinder
Also I should mention I have tested fuel pressure and it falls within spec. Thanks again!
New parts include -
Plugs
Wires
Idle Air Control
Both O2 Sensors
