my 2.9 running rich= flame thrower lol
slow96gt
U.S. Military - Active
shelbyville tennessee
ok my 88 ranger 2.9 has been running super pig rich i have no idea why, i replaced the map sensor and 02 which helped all the surging it was doing around 2k-3k rpms but it runs great just at idle its super diesel black smoke rich since i cant seem to figure out the problem i decided to make a flame thrower out of it lol but if anyone knows what could be wrong that would help put alot http://www.youtube.com/watch?v=4f68IMFDetw
Psychopete
29
FW, IN
Could be a failing fuel pressure regulator. Best way to diagnose if this is it is checking the fuel pressure with a gauge. Also a quick check is if you have fuel in the vacuum line from the FPR to the lower intake.
jhammel85
Guest
:shok: You made a flame thrower out of it? lol...
Well, My truck ran rich just like that when the regulator went bad. Check the pressure. Should be 35-40 with the key off and somewhere between 30-40 when running. Preferably 35 PSI if I recall correctly.
When my regulator went out, it was pegging the gauge at 100 psi+. That is the only time I have ever had one totally fail like that. Also, the diaphragm wasn't ruptured and leaking fuel into the vacuum (might be worth checking that vac line)
slow96gt
yea thanks guy but i got so mad at it tonight i pulled the 2.9 and doing the 4.0 swap so this should be fun lol i was getting around 2-4 mpg like that and i couldnt handle it anymore
slow96gt
yep around two to four it blacked smoked worse than a diesel, something was causing it to run super rich
Acepilot1023
East Coast USA
2.9L
How much do you want for the 2.9 you pulled? :D
ranger
Pittsburgh,Pa
Mazda B4000
2.9L
should of taken a video of it blowing smoke lol
Acepilot1023
East Coast USA
2.9L
Name your price, and I will deff consider it.
Acepilot1023
East Coast USA
2.9L
Yeah, deff next time we go to the mountains
Mike Tonon
Guest
Pipe the exhaust back to the engine intake and your mpg's will improve!!! lol
ereinhardt
1987 & 1990
Hey, Im currently having the same troubles with my 87 2.9L. ive replaced the 02 sensor, map sensor, temp sensor, egr sensor, cleaned the egr, changed the plugs, wires coil, checked grounds, throttle pos sensor, checked the fuel pressure regulator and still the same thing. after burning so rich my cat plugged up, so i cut it out and just connected with a straightpipe, but still doing the same thing. ive checked all over online and its driving me nuts because no one seems to know and there handfuls of people who have the same trouble. my next step is the computer. apparently if its been jumped frequently it can surge and fry the computer. which makes sense because i had the truck parked all summer because i was driving my 5.0L. the battery died and everytime i needed to start it i just jumped it to keep it in running order. ever since i started driving it full tim again im getting TERRIBLE gas milage and super rich black smoke. so i took out the computer and it said "Note: only for 3.0l Taurus/sable only" i should be getting a new computer this week and i'll see if its the solution, even though you've already pulled the motor
slow96gt
yea icouldnt figure itout either so i said screw it, the 4.0was the best thing ive ever done to this truck
