My 100hp motor killing my 7.5
CT
1987
2.3 & 7.5 460
My truck has a 2.3 5-speed with 100,000 on it. Tranny making a little noise but is all that HP too much for the 7.5 in it? The truck clunks when driving (letting up on the gas). The u-joints are fine so I think it is the rear. with the truck parked and in 1st gear I can push the truck 6 to 10 inches and it makes the clunk noise when it rolls back. What do you think? Am I right about the rear. Thanks
babytruck
Olathe, Kansas
i dont understand what you are trying to say??? i would like to think that 100hp wouldn't shell a 7.5 rear end. maybe its just its time. does the truck jump or ride unusual? might be your rear drums or parking break.
CT
1987
2.3 & 7.5 460
Truck runs and drives fine. Just making a nasty noise every time I take my foot off the gas.
Moto Mel
Va. Bch., Va.
1994
19
Li
Sounds like the gears are worn and the rear will soon give up on you. Jack the truck up and grab 1 wheel and turn it. Have the trans engaged/in gear and if its a Traction lock diff. You will need both wheels off the ground when you turn the wheel with some force forward and back, if you get a lot of movement front to back, you have a diff problem.
Or, there could be excess backlash in the gears because the crush washer has somehow gotten crushed even more than originally set, another suspected item would be the pinion bearings are wearing out.
Mac
183
C. Wisconsin
2000
199
What size tires you running? A 7.5 has lived behind a mild V-8 with no problem, driven correctly.
Dave
CT
1987
2.3 & 7.5 460
I put on 235 75 15 on it about 1000 miles ago.
Those still aren't huge. the 7.5 should be able to handle them. It may just be time for a rear end re-build. They do wear out eventually, some faster than others.
Hopman
13
Manch-Vegas, NH
2.3L
I've got 154,000 on my '94 2.3 5-speed 4x4. Oh wait. The 4x4 Rangers have an 8.8 right?
um, 2.3L 4x4 might still have a 7.5
Andres629
11
Saskatchewan!
2.9 screamer
Well... it's probably not KILLING your rear end if that even is the problem. My 7.5 stood up behind my 2.9 with 33's on it, so it's probably just wearing out, or the crush washer got crushed even more as has been said. Mostly just an age thing I imagine.
Andres629
11
Saskatchewan!
2.9 screamer
No, only the 4.0L Rangers came factory with an 8.8
babytruck
Olathe, Kansas
it wont matter if its 4x4 or not you just need to check the tag on the rear diff. it'll tell you what rear you have.
Mac
183
C. Wisconsin
2000
199
The only thing for certain is that all 4.0L came with the 8.8. Others, even some 4x2's came with the 8.8.
Dave
LearjetMinako
12
Moore, OK
2.3L 140ci
125K miles on my 7.5" axle, no problems yet with a 2.3 5-spd in front of it.
