mini starter for 4.0 manual?
DaddyKnotts
southern pennsylvania
1992, &1989
ford, &ford
4.0, 2.9
helo my starter went out and id like to make it better rather than just replace it, so i was wondering if there is a mini/high torque starter that would work for my 1992 4.0 manual ranger? please help soon as this is my daily driver
8,374
No, starter motor generates too much heat for a "mini" version to last very long.
DaddyKnotts
1992, &1989
ford, &ford
4.0, 2.9
thanks.... but someone had suggested to get one, he has a suburban with a high torque mini starter on it that came off a newer s10, it starts up like a little tuner car quick and lively... i was just looking for the equivalent for my 4.0
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
My stock starter has never had one issue, nor is there any real space concern to require anything different.
The solenoid went out once, so I swapped it out with a random OEM 4.0 auto starter I had laying around...but that's it.
3,614
There really isn't anything. The 4.0 already has the smallest starter Ford ever used on the V6s, and Chevy has a lot more parts interchangeability than Ford.
Also, aside from satisfying your jealousy, there is no point. Started is started. You may find that a new starter will do what you want anyway.
holyford86
Some guy with a problem
638
Plattsburgh, NY
many
33x12.50R15
The 4.0 starter is high torque, they use the same internals as the starters on much bigger engines (like the 6.8l v10).
Sent from my XT897 using Tapatalk
