Military Mazda B4000 Bulls Build
Kyle M.
GOING FOR BROKE
9
Howard City Michigan
You are paying someone to do this?
frankserrano
Hudson, FL
4.0L, 5.0L
that shop owner must've reallllllly owed you a favor lol
bull90
Canadian Military - Active
mazda
4.0 Litre
1988 FORD F150 5.0L 302 EFI A4LD Tranny Donor Vehicle/Winter Beater
BIG OLD BAG OF SHIT!!!!
but the 302 5.0L EFI only has 85 000km. Paid 600$ for the truck!
im pretty sure my BW1350 will bolt right up to the tranny. and this swap should go well! next years plans!
Andres629
11
Saskatchewan!
2.9 screamer
I hate to be a downer, but do NOT use a 1350. If you're going linked/coilovers you're likely looking at a relatively large amount of wheel travel, am I right? You'll bust the snout off the front output on the t-case if it drops too much and you romp on it. Just my .02!
bull90
mazda
4.0 Litre
the bw1350 is the doubler. im picking up a dana300
Kyle M.
GOING FOR BROKE
9
Be prepared to change the output shaft and rear tail of the tranny.....2wd trannys won't bolt up to transfercases with I am sure you know, but never know.
superds
80
ND
Ford Bronco II
2" body. 1.5" coil spring spacers/rear block
Correct about the rear tail of the 2wd tranny.
Also, if you started with a 1/2 ton+ 4x4 tranny then the tailhousing to tcase is a 6 bolt mounting design, where the 1350 is a 5 bolt mounting pattern. You would need an adapter to put a half ton tranny to a 1350.
Good looking build so far.
bull90
mazda
4.0 Litre
im pretty sure its a A4LD Tranny which should bolt right up.. i know i must remove the tailhousing but idk whats under neath that. the shaft needs to be shorten?
if im wrong then its a AOD tranny? and i can buy this P/N 50-8405 - AOD (1988 & up) to Borg Warner 1350 T/C. (Adapter length of 5" or 9")
http://advanceadapters.com/product/1805/50-8404.html
My Transmission code in my door says "T" which would mean i have a A4LD. but its a f150 and everyone tells me they didnt have this tranny.
did some double checking and with the markings on the trannys oil pan and the tail housing bolt pattern i think ive come to the conclusion i have a 4R70W Tranny which is the same as the Explorer and a adopter is needed 550$...
bull90
mazda
4.0 Litre
anyone got ideas on how to make power out of this engine?
i was thinking headers, exaust, computer, Efan.
i also heard that i can put 351w Heads. what can i do for more torque? i know these engines arnt known for there torque but maybe i can change that?
Kyle M.
GOING FOR BROKE
9
You gonna keep the efi? You could swap the ecu with a mustang(and cam too) then you have lost of options. Like cam swaps, intakes ect...
Andres629
11
Saskatchewan!
2.9 screamer
A set of 5.0 Explorer heads would be a great addition...
bull90
mazda
4.0 Litre
yeah i wanna keep it EFI.. i want it to start in the cold mornings of Northern Ontario! soo mustang ECU, GT40 Heads, After Market Cams.
But what Cams i know theres different lifter and duration. mustang cams are??
any intakes that i can buy to eliminate that damn double intake?
Maybe use my imagination and build something... with a K&N
i have a Flowmaster 40 Series that was on my Mazda when i first got it. i think it will be a fine addition with a high flow CAT
also seen someone changed the truck to Mass Airflow Sensor. this could help with a lean gas mixture after some exhaust and intake changes.
i was told theres longer header are better for torque is this true? and does anyone know how much they cost!
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
I've never had a problem w a stock 302. They've always gave me plenty of power is my 92 ext cab. That's just me. I thought those trucks came w the AOD, then the E4OD. IIRC
kolton
U.S. Military - Active
lewisville, Tx
Man, I wish I could throw money at my truck and call it done. I think it will look cool though. What are you going to be using it for? Winter vehicle? Or trail?
bull90
mazda
4.0 Litre
the mazda is gonna be used every day hopefully :p why own a vehicle if you cant drive it around city streets to turn heads. ford is only gonna last 1 year if all goes to plan. next summer im taking a week off work to put the 302 in and to have a little fun!
