computersoc
- Apr 16, 2013
- 3
2001 Ford Ranger XLT 2.5L RWD, has ABS
How many brake lines does this truck have? I went to a mechanic and said I want all my brake lines changed. Nothing under the hood is new going to the master cylinder (aside from the newer looking one that was replaced a few years ago that goes to the rear) and then under the truck the line at the rear differential wasn't replaced either. Before I accuse the shop of anything, is there anywhere else that I should check to see if they misunderstood and replaced instead?
I gave them this also:
The one guy at the shop even said the under the hood ones are fine but they don't look it.
Amazon.com: 25 Ft. of 3/16" (4.75 mm) Copper Nickel Brake Line with Fittings: Automotive
Buy 25 Ft. of 3/16" (4.75 mm) Copper Nickel Brake Line with Fittings: Brake Lines - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
