M50d r1 oil
97ranger2.3
Pennsylvania
Ford ranger
So what oil does everyone prefer to use in their 5 speed trans? Is cheap ATF good enough? Is the more expensive stuff necessary or is it all hype? How about pennsoil? Syncro?
any thoughts?
8,372
It only holds 2.8 quarts bone dry, usually only takes just 2quarts after draining
So not a big expense in fluid
Mercon V or equivalent is spec'ed by Ford, now called Motorcraft XT5QMC
Many like synthetic version, I still used Mercon V
97ranger2.3
Pennsylvania
Ford ranger
ok thanks
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I've seen some issues with Mercon V causing hard shifting in a manual trans... I recommend (specifically): "Dex/Merc" fluid. It matches the original Mercon specification for the M5OD transmission (all before 2008).
If you want a synthetic, Royal Purple Synchromax should be a good bet that is made specifically for manual transmissions that normally take ATF (I have that in my '90 trans, though I can't comment reliably about shift quality since my '90 trans was previously a victim of Mercon V).
racsan
4,490
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
I have ran the pennzoil syncromesh fluid myself for several years with no problems, The recommended fluid for this transmission is atf.
