- Mar 9, 2012
- 4
- Ohio
- Ford
- Engine Size
- 3.0
When I put my truck up on blocks to start working on the suspension lift, the diff started leaking. There have been no spots in my driveway or anything so it's somehow convenient it did this when I plan to have the whole thing apart anyway.
It looks like the pumpkin can be unbolted from the cover, and then there is a bolt on the back-driver side that it would pivot on. Is this actually a pivot bolt?
I'm hoping to not have to pull the whole thing apart given that the leak looks like the passenger side shaft seal... Just permatex the main gasket and be done.
Don't have time to do the U-joint upgrade or c-clip eliminator, which sucks.
Another question: can the pumpkin be removed without pulling everything down to the knuckle? I remember that the passenger shaft can be pulled apart at the slip joint to keep from having to remove that side (although I need to do spindle seals anyway...)
