I have made some good progress. My stupid Jeep took a dump 2 weeks ago- so I got side tracked by that thing. Its pretty rough when 2 out of 3 of my vehicles are inoperable. The operable one was my kids bronco! I thought the jeep could wait until the ranger was done, but it started throwing a misfire code and tried to leave my wife stranded. Its one of those things too- once it is on the lift and I start pulling parts, I might as well do everything it needs. The jeep got a catalytic converter, a clutch, oil pan gasket, rear main, valve cover gasket, starter, crankshaft position sensor, throttle position sensor, plugs. Rockauto also sent me the wrong clutch- different number than what I ordered- so that was a delay. I think it is going to run now and not leave my wife stranded- so back to the ranger, bonus- I think I got the oil leaks sorted on the jeep.
I have been waiting this whole time for the tranny to be done and for the heads. Finally, I got a call on the tranny- so I picked that up. Completely rebuilt with all new soft parts and the 2.4l gears. The rebuilder said both trannys were in exceptional shape when he pulled them apart. Not bad for a 313k mile 4.0 tranny. It was nice of them to paint over the grease that was left on there. Luckily I powerwashed it twice before taking it to them.
I also decided to swing by the machine shop and check on the heads while I was out. Turns out they have been done for a couple weeks and I had no idea. Thanks for the call....
They ended up not telling me what they decided was best either. But whatever, at least they are done. They put the new valves and springs out of the NOS 93TM heads into the 95 heads. The rebuilder said I need to buy a lottery ticket because the 95tm heads I brought him were not cracked. I told him the 95 variety aren't that prone to cracking.
They supposedly boiled them, but they didn't come back that clean.
maybe it is normal- but I was disappointed. The intake runners were full of carbon and oil. I spent a whole evening with a brush and some cleaner trying to get everything clean. I wish I would have done it before I took them to the place.
They also decked them .009. That should increase my compression a little bit. Also did a multi angle valve job- so that should increase performance. They had to do 12 new valve seals and 6 seats. I dont know why just 6 seats. The guy I picked them up from was about 97 years old and the tech didn't remember anything. I need to call and talk it over.
I started to install the heads on Monday- but then I realized I was missing 4 dowel pins on the new block. So I tried to get them out on the old. That worked not at all. I called ford and they had 4 in stock so I was able to pick them up yesterday.
Last night I got the new heads on and the lower intake. The valley needs SO much RTV to seal. I am hoping it does seal! probably 1/4" in the back. The gasket didn't have anything for the valleys.
Here is my lab. Its been fun to work with my dad on this. He is 72. I won't have his help long.
One last thing, my cousin who was an engineer for ford gave me a FSM. That thing is SO perfect for work like this. So detailed.
