Oops
Did you somehow replace the tone ring for one with more teeth or something too? How does changing the gear ratio change the speedometer on a '98up truck where the tone ring always rotates at wheel speed?
Now that I think about it, your right. Changing
just the gears would NOT fix the speedo. I changed my gear ratio by changing the complete rear axle from a 7.5"rg to a 8.8 from a LevelII Ranger. The tone ring had a different number of teeth and
thats what fixed my speedo to match the change in tire size.
I guess I got this confused with my '78 dodge. That one started with 3.23 gears and 235.. tires. When I went to 4:10 and 33" tires the speedo corrected itself. I had forgotten all about the tone rings on the Ranger. Sorry for the confusion
Does the size of the ring gear always determine the number of teeth on the tone ring, or can you get different tone rings for a particular size ring gear?
