i want a 5.0
mayito
Chihuaua, Mexico
i have a question, i want to change mi 4.0 to 5.0, and the most thing is worring me is gas mileage, i have 4.56 and 35 tires and i want to usea a 5.0 with 5 speed, now mi truck is given like a 4 Kilometers/liter, is a lot of gas in a low of miles, and i dont want to spend more gas, maybe the same quantity of gas, did someone know how many gas spend the 5.0 , 5 speed and 4.56 wiht 35 tires ?????????????????????????
thanks a lot
baddad457
18
Opelousas La.
You need to convert the liters per kilometer to miles per gallon for us:icon_confused: Roughly, I'm thinking that's something like 16 mpg. A V8's going to be about the same, depending on your right foot.
projectnitemare
8
Osceola Mills, Pa
396W
A V8 can give you better and worse milage. If you drive it like an old man the extra torque and power will help you out a little in the milage department. Just about every person I know or have helped do a V8 (stock V8) has increased their milage when they drive normally. None of these trucks were lifted so I don't have any numbers for you. My truck is similar in size and specs to yours, with my large V8 the best I've every managed is 16mpg on a good day. As soon as you start getting happy with the gas you will do much worse than you could have ever imagined. The easiest 5.0L and 5 speed setup you will find will be from an F-150, take engine and transmission, use the t-case if you want; it's a little large. Or look for something older to take the t-case from the NP 205 or 208 are the best fits.
Matt
Ranger5.0
Lindsay Ontario
i get about 18mpg on the highway with my setup, and my engine makes more noise and smoke then power these days. Its exciting to have a V8 in a ranger which makes it hard to "drive like an old man"
mayito
Chihuaua, Mexico
question
ey man, that is better 18mpg than 16, but i have a question, if you speedometer say`s 60mph what is your real speed ??????
in my truck that saids 60 and i go like a 55
thats what i want to know
thanks
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
4Km/L converted to US MPG is 9.424mpg, that's pretty bad and makes me suspect he didn't recalibrate his speedometer/odometer.
I've never heard of a 4.0 getting mileage that bad unless itmwas being run in low range.
AD
baddad457
18
Opelousas La.
I came up with 15.14 mpg. There's 3.7852 liters per gallon.
Ranger5.0
Lindsay Ontario
when my spedo says 100kph, im doin 100kph
Ranger5.0
Lindsay Ontario
LOL Thats bad dude....veary veary bad lol
mudranger
Florida
I am getting 17-18 mpg out of the 5.0 v8 w/ 32" muds and 4.10 s with a locker...as long as I keep my foot out of it....
