- May 14, 2018
- 1,097
- Western Mass.
- Ford/Ranger XLT
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 2WD
- Tire Size
- 225/70/R15
- My credo
- If it's not broken Don't Fix It!
This is exactly what has me confused. But with the given information it suggests the only cylinders constantly firing are 2 and 4. The key word here is constantly.It wouldnt even start on 2 cylinders.
@OP at night in. Dark area pop the hood and run the engine. Look for skark leak through all plug wires down sides of plugs and across the top of the cap. At night you will be better able to see it spark jump and see the blue arc run across things.
It is always possible to have 4 injectors getting plugged and limiting fuel delivery but you need to be sure there is no spark issue first before going this far and either testing or replacing them. So again double and triple check under the cap for ground traces after the night test. The traces will look like a light pencil line leading to a grounded surface. These can run in between plug posts also or even down the rotor to the distributor shaft.
