Turbo works on flow. The more flow you have the faster the turbine spools. Faster the turbine spools the sooner you'll be making power. Back pressure is created by restriction in the system, and restriction decreases flow. If the restriction created down stream of the turbine is a bigger restriction than the turbine itself, that restriction limits the performance potential of the turbine. Ideally you want to the Turbo to be the largest restriction, source of back pressure, in the system. Back pressure down stream of the turbine is fine, so long as it is lower than the back pressure upstream of the turbine. Hope that makes sense, it's been about 6 years since I graduated from the Aviation Maintenance Tech School where I learned what I know about turbines.
Armadillon, I might try to find information/proof to back up my claims after you provide the same. The example you give is a factory turbo install, it was designed to work within factory specifications. You modified things so that turbine was no longer operating within factory specifications and you did nothing to upgrade the turbo itself. What kind of results did you expect? If you expect us to provide proof to back up out claims before you will listen to them, then do the same.
