'90 Ranger 4.0L 2wd
When it is cold outside (under 45F) my truck has a fuel leak that smells really strong. I noticed it last winter, but once the weather warmed up it completely went away. Never smelled it once. Now that it has gotten a little more chilly the smell is back. Also, when I try to start the truck in the morning, I have to crank the truck longer then normal for it to fire up. My guess is that the colder temps cause some crack to get a little bigger and air gets into the lines. The leak does not seem to be so big to be causing any drop in MPG. It is just big enough to make me dizzy on my way to work
The problem with all of this is that I have tried to find a leak but have not seen any. I guess I really don't know where I should be looking, and the easiest way to try and find it.
