289-tiger-
- May 10, 2008
- 0
- Ford
Respectfully, I will name a heat source near the filter, it is the engine and exhaust system. 40 psi+ and a small leak could be an issue (where it squirts and how hot the surface the squirt gets to is fate) I have seen many vehicles burn, but in order to keep it into Ranger classification while trying to help a motorist with a 90-92 Ranger burning from the driver front wheelwell in 1995 in Gainesville Virginia, the couple of minutes/seconds it took to turn around, call react on the CB and try to unstrap an extinguisher only resulted in myself and the owner watching his vehicle burn to the ground.first of all the only thing holding those lines on is a plastic clip, and second name one heat source remotely close to the fuel filter. I had an old on that leaked and a little o-ring sure as shit did solve the problem. and I said replace it to begin with. look on this site and you'll see alot of people who've had a 10 dollar fuel filter be the problem. Alothough "stuff" probably was bad wording. haha. I "slid" one on the filter till it hit the hump.
Good luck
