How tf am I supposed to search?!
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I'm not a guru....
try writing a/c in long form.
Maybe quotation marks around the numbers? Or around the whole search term?
PS, welcome to TRS.
8,372
Welcome to TRS :)
Most "search engines" have common characters you can use
+ is used between two words that may or may not be in order in your search, "2002 + drain" would find posts with both words 2002 AND drain
* is a wild card that means "any letter or space" is OK,
The letters A and C are every where so you end up with every post here, lol
4.0l is also way too common
But I doubt you would find that specific info here in any case
Try 2002 + drain
But a google search might be better using 2002 ford ranger evaporator drain location
Bird76Mojo
1,265
IL
I often have better luck by using Google and searching with keywords like "Ford Ranger A/C drain location" - you can add things like "TheRangerStation" or change your keywords like "A/C to AC" or "Air Conditioning"
I wouldn't search, I'd just ask,
It will be near the bottom of the evap casing.
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
8,372
Spoil sport
He was asking about "searching" for the answer, not the answer itself
Spoil sport
I get that, but that one is so oddly specific that I don't know if you could ever find it in the forum. It isn't a topic we cover 100 times a day like "which spark plugs are best" or "What's the cheapest way to get to 1000 HP with a K&N intake?"
8,372
Oxxon
51
Brownsville, Tx
Hello and welcome to TRS!
