How do you break off a lug nut
Ozwynn
200
Berrien Springs, MI
RE Interceptor
How do you break off a lug nut that’s been rounded and cross threaded? Asking for a friend that apparently can’t use air tools
ericbphoto
Overlander in development
TRS 25th Anniversary
16,784
Wellford, SC
6"
If it's that screwed up, I think I would jump straight to drilling the stud out of the center. Thn lug nut falls off. Remove the wheel. Replace stud.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
Yeah… thanks man. It has to go to a shop for that, so to get through our work day I just plugged the tire and aired it up. We don’t take this truck out on the hwy anyways.
Uncle Gump
Token Old Guy
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
use a damaged lug nut removal socket... about $20
rumblecloud
1,136
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
racsan
4,518
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
If its on the front of a drop-center rim (steel of course) Id just torch it.
lil_Blue_Ford
6,284
Butler, PA, USSA
4.9L
racsan
4,518
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
Id think the heat would damage/distort it though.
Roert42
5,067
Kintersville, PA
Ranger XLT
4.0 SOHC
Aluminum is a good conductor, so the heat will dissipate faster through the aluminum then the steel.
19Walt93
4,502
Canaan,NH
351
3"
235/55R16
I've seen many aluminum wheels damaged by guys trying to cut off lug nuts, don't do it. The sockets posted above or one sold to remove wheel locks would be the way to go. You need an impact wrench to use the lock removal socket.
lil_Blue_Ford
6,284
Butler, PA, USSA
4.9L
It’s possible to damage both aluminum and steel rims with a torch, but you can’t cut aluminum with a normal torch because a torch cuts by oxidizing the metal (rust), and aluminum doesn’t oxidize the same way plus it’s a good heat conductor. I’d only resort to a torch as a last resort though and I’d probably start with trying to heat the nut before pounding a socket on and hitting it with the impact before resorting to cutting.
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
What happens if you try to torch cut aluminum? Does it just melt?
lil_Blue_Ford
6,284
Butler, PA, USSA
4.9L
I had thought it would, but it doesn’t cut or even melt well with a torch. A least not a rim. I slagged a couple nuts and studs on a junk aluminum rim (they tried to cut the lugs off with a grinder before I was recruited to use the torch). I melted the steel and blew it out as slag and about the only real damage the torch did beyond the grinder marks was burn the clear coat and leave black soot.
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Its crazy never had the thought of what happens when you try to torch cut aluminum. It so soft I just use saws meant for wood and not tell the carpenters lol.
lil_Blue_Ford
6,284
Butler, PA, USSA
4.9L
Yup, and actually abrasives intended for steel/stainless steel (like cut off disks and grinding disks will load up with aluminum rather than cut. Aluminum requires an entirely different cutting method than steel
No members online now.
