Help on finding lift kit
ranger28
hello i got a 1998 ford ranger xlt 4x4. i want a 6in or 8in supiesion lift does anyone know where i can get them
89PBR96
Pekin IL
I ordered mine from National tire an wheel NTW got the 6 inch suspension special it was 499 shipped everything you need besides brake lines
bcost882
5
The Queens Country.....
3.0L, 1.6L
He has a 98 that was the start of the a-arm suspension. Rcd used to make a 6in lift for it but good luck finding one. Super lift makes a 4in for it. then you would have to add in a 3in body lift to get it up where you want it. but the only way you can, at the moment, achieve 8in of suspension lift is with a solid axle swap.
89PBR96
Pekin IL
That is right 97 was the last year for the lift I ordered sorry man
bcost882
5
3.0L, 1.6L
i've done that before no big deal man haha
ranger28
thanks yall and also is there any other year of lift that will work on mine
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,840
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
wahl_7s
Whittier, CA
FORD
6.4,3.0,3.0,4.0SOHC
Call Dixon Bros I raced with Aaron hes a good guy he'll be able to tell you what's possible! 4" w/33's is pretty hi that will get you about 6" over stock. we used to pre-run with a 94 4WD with 35's was plenty high enough for off-roading
ranger28
thanks now with the axle swap what should it be......?
