HELP, I want to lift my 1986 2WD Ranger w/ Manual Steering
GavinHimebauch
So here’s my dilemma. I own a 1986 Ford Ranger with the 2.3l and 5spd manual. I want to put a cheapo rough country lift for aesthetic purposes and maybe do some beach cruising. However, my truck has manual steering which RC says will not work with their kit because P/S and M/S have different pitman arms. RC also says they do not make a pitman arm and don’t know anybody who does. Can I make this kit work? If so how? If not what are my options? I’m looking at a 4inch lift. I don’t want to do a body lift either.
Thank you in advance
Best regards
Gavin Himebauch
BlackBII
Ranger Custom
Truck of Month
982
UT
Th manual steering box on our rangers uses the same sector shaft splines as the Saginaw 525 and Jeep manual steering boxes.
A stock manual steering XJ arm will work for you, although it may not be quite dropped enough; you may want to see if you can find a drop pitman arm for a manual steering XJ. It's the one in the middle in this pic. Part number Crown Automotive 52000616. The spines are off center by one spline though. The 4 square cut splines will put your arm off to the left by one spline.
