Harness questions/issues
ReptileChillock
Hey, I'm finally putting my Ranger back together after what turned into a full on rebuild.
It's a 97 2.3L 5spd, poverty spec. No AC, no power windows and I swapped in a manual steering gearbox.
I'm down to the last few things I gotta hook up, but I'm not sure on some of them. I labelled *most* things, but those few I didn't really came back to bite me in the...:dntknw:
So, I guess let's start off with the most worrying.
Sorry it's upside down, but this is facing backwards from underneath the truck. It's the rearmost plug on the trasmission. I can't for the life of me remember where that blue plug goes, if anywhere.
There are a lot of plugs that go nowhere on this truck, and I didn't take notes.
I'll try to get more pics, but where the transmission harness meets the other 'main' harness, there are three plugs. The tranny harness only has two I can find, so I assume it's for an option I don't have. The plugs I *did* use where white and grey circular ones, the remaining plug is black.
Then there's the issue with this thing:
It's behind/below the fuel rails, coming off the block. I think I got it right, and connected what I assume is a ground wire to it. Green wire with a little pop-on cap thing.
Moving on, I have no idea where this guy goes:
And while I'm at it, I'm not sure I hooked up the throttle body correctly. I know it's not the right subsection, but I don't want to start a thread for one question.
I've attached the hose to the bottom of the TB,
and I assume that hose hooks up with the intake manifold right at the little nub that splits off before the bigger connection here:
ReptileChillock
OKAY! So I've got a lot of it figured out. The white cylinder thing is the PCV valve, and I found where it goes. I've got everything done except for the charcoal canister.
ReptileChillock
Everything's connected, nothing gets power.
Go get a good voltmeter and follow the power.
Check for 12V across the battery, and then follow the positive power cable along and see where the power stops.
8,372
There are a few things that have power all the time.
Dome light, brake lights, and head lights, key on/off doesn't matter.
If those are not working then check battery cables, make sure Black Ground cable is hooked up to the engine, and engine ground straps go to the firewall and frame, if you left these off to test the engine, put them back on now.
There is usually a smaller black cable from the battery, or frame, to the Radiator support piece, that grounds the head lights.
The grounds are 1/2 the circuit, so if you got a bad ground you got no power.
Red battery cable should go to the starter motor's solenoid but also to the Power Distribution Box in the engine compartment, that's where I would make sure you have power, check for power at the fuses
