- Jun 25, 2021
- 23
- Age
- 47
- Abilene tx
- Mazda b3000
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 2WD
All parts ordered finally came in yesterday. Tearing back into it to replace the lifters, pushrods, bridges and injectors. Wish me luck cause I'm getting tired of JACKING with the MANGER. I've had this thing since April and in the last month and a half have put roughly $1200 into this purchased for $3000 truck. I thought only JEEP stood for "just empty every pocket"...... but if it's good then the only thing left to go wrong would be pistons, timing chain, water pump or crank cause everything else is new...
My understand here is to use assembly lube on the lifters and all metal to metal contact points, load lifters with torque specs from rockers, fill lifters with oil best I can, prime by turning through cycle a few times by hand, check everything then start putting it back together, correct.....
