Fuel Air sensor amongst other things.
martin
26
St Bruno, Quebec
1991
It sounds like the pump is not running when the key is in the run position.
modelageek
14
Boston, MA
if your having this issue without any CEL. I would suspect fuel pressure. pull the vacuum line of the fuel pressure regulator and check that there is NO fuel in it. if that is ok i would do a fuel pressure test..............you put the fuel filter in the correct direction right?............
McFuzzie
Vancouver, WA
4.0 L V6
Ok, I'll try that.
Yes, I put the fuel filter in the right way.
McFuzzie
Vancouver, WA
4.0 L V6
It is, I can hear it. Plus I replaced it less than a year ago.
