Fuel Air sensor amongst other things.
McFuzzie
Vancouver, WA
4.0 L V6
So I took my '91 Ranger in to the shop to get a diagnostic ran on it because it wasn't starting and wouldn't keep running and bogged when it did. Here's what they said was wrong:
-Fan Clutch
-MAF Sensor
-Fuel Air Sensor
-Alternator
-Power Steering Hoses
Is the "Fuel Air Sensor" the O2 sensor? Because I can't find anything with that specific name. I'm also only going to fix the MAF, "Fuel Air Sensor", and the alternator right now because of money. Finally, what is the fan clutch? Is that what engages/disengages the fan?
Thank you,
Kyle
bmonee5
Oregon
well the MAF is the Mass Air Flow sensor, i've never heard of a "fuel air sensor", but then again i'm no mechanic myself. yes the fan clutch controls the speed of the fan off of the temperature. Seems kind of weird that they found bad power steering hoses when diagnosing starting/running issues..? But good luck with everything, i'm sure it'll run great when done.
McFuzzie
Vancouver, WA
4.0 L V6
Thanks. I know the MAF is the Mass Air Flow sensor. I'm pretty sure it's the 02 sensor because isn't that what O2 sensor does? Measure the ratio of air to fuel?
88_Eddie
156
Raleigh, NC
2.9L, 4.0L
yeah, that's what an 02 sensor does, it takes that info and mixes it with info from other sensors and determines how rich or lean your engine is running.
did you get your codes pulled? it's free at most autoparts stores. go to one and then post what the code numbers are. i'd try cleaning most of that stuff before i replaced it. an 02 sensor will run anywhere from $50-$75, a MAF anywhere from $50-$150, so i wouldnt start replacing stuff until the problem goes away.
and just remember, unless you know the shop real well, they can be trying to dick you over. i work at autozone, and once a week someone comes in looking for some nonexistent part that some shop told them they needed. today's was funny, a state inspection shop told a guy they had to do a $10 window tint test, guess someone needed beer money
McFuzzie
Vancouver, WA
4.0 L V6
A window tint test? lol. Wow.
But anyway, I've tried pulling the codes myself and I didn't get anything except the code saying "pass". Plus, my check engine light isn't on. I've tried cleaning the MAF sensor and it helps for like 5 minutes then the bogging continues. I've tried to let it idle then unplugged it and it ran better, so I'm pretty sure it's bad. But I can't really double check that because it wont start now.
sholzy
Texas
Did you reset your EEC after cleaning your MAF?
McFuzzie
Vancouver, WA
4.0 L V6
Update: Just replaced the MAF sensor. Starts for a second then dies. So still not fixed.
sholzy
Texas
Are you getting fuel and spark at the cylinders?
bobbywalter
TRS Technical Staff
2,889
woodhaven mi
FORD mostly
BIGGER
sawzall?
is there a hole or loose hose in the intake system?
McFuzzie
Vancouver, WA
4.0 L V6
I'm going to double check spark tomorrow.
The intake system looks good. No holes or broken pieces as far as I can see.
McFuzzie
Vancouver, WA
4.0 L V6
So I finally got around to check the spark, and I'm getting spark.
Would an O2 sensor stop an engine from starting even though I don't have a "check engine" light?
Yellowsplash
9
Morgantown, WV
No...the vehicle can run without o2 sensors, as it does before it reaches normal operating temp.
