Front Drive Shaft U Bolts
csampson311
4.0L V6
alwaysFlOoReD
5,152
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
'91 ranger @ the pumpkin is strap and 2 bolts. I can't remember the other end.
Richard
legoms013
09/2013 OTOTM
26
CA
4.0L V6
You could drill them out and use these like I did:
Strap Delete Mod:
Tools needed:
1/4" drill bit
5/16" drill bit
cutting oil
13mm end wrench or standard equivalent
external #25 torx bit
pry bar
3/8 drive or bigger drill gun (battery or corded)
Time needed:
Less than an hour
Parts:
Precision 534-10 U-bolts (got mine from RockAuto, $9 shipped)
csampson311
4.0L V6
^^^im diggin this. Looks like its pretty damn beefy. Ill definitely look into this later on but for right I just want something simplistic like stock.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
It took me less than ten minutes to do this modification. I tried the straps first but broke 3 out of the 4 bolts off while tightening them down with a 1/4" ratchet. Hopefully that will tell you how weak the stock setup really is.
I got my u-bolt straps at Advance Auto under their help section for around $10.
85_Ranger4x4
17,976
SW Iowa
I have had mine out a couple times over the years, I did put in new strap kits for peace of mind when I was doing my V8 swap... never have broken a bolt though.
I do despise getting a hold of those little bolts, had I known about Brinker's truck I would have gone that route.
yodaman1151
Oregon City, OR
2.9L V6
I strip out the torx heads on the stock ones
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
the stock ones blow, i used the same thing legoms did.....81004 is the part #
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
I see you use BruteForce u-joints too, 88_Eddie lol
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
yep, got mine at auto-bone while i was working there. paid $4 for both i think (20% discount)
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Aren't these properly named "Brute", but it should have been spelled "Brut". As in they are to U-joints, as Brut is to cologne?
Seems like I heard they are not so good.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
I've never broken one on the 3 different vehicles I've beaten with lockers, low gears, and 35s+
csampson311
4.0L V6
I picked up the 81004 ones from my local Oriely's last night. I cant wait to put the drive shaft back on today after work. I will no longer be lying when I tell people it 4X4 :yahoo:
