Front axles turning in 2wd
Uncle Gump
Token Old Guy
13,486
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
This is EXACTLY why I asked @StanC to post his own damn question in the first place.
StanC
Va
Gentlemen, thanks for all the replies.
snoranger That's the post I am speaking of, the F150 or expedition. I know this is a Ranger forum but this is where I saw it. I have been chasing this issue for about 3 weeks since I got the vehicle. I have a 2017 Expedition Limited. It has IWE vacuum locking hubs. I have a hum at highway speed in 2wd. Basically Everything works as it should but my front axles turn when driving in 2wd.
This is what I posted in the expedition forum.
To double check the IWE's and the hose leading to them I used the vacuum line at the IWE solenoid to pull vacuum to both IWE's and it held at over 20in for 20 minutes, wheels spin without turning axles, until I disconnected my vacuum pump then the wheels are connected to the axle shaft as they should be. Then I connected everything back and pulled the line off the reservoir, vehicle off, and there was existing vacuum there. So I believe the check valve is working. It seems like everything is working as it should. I even confirmed the front drive shaft is free when in 2wd with the vehicle running by rotating by hand. The problem is I get a noise from the front end when driving, sounds like a wheel bearing. I installed a new motorcraft hub/bearing on the drivers side and the noise is the same. So I mounted a GoPro to the frame and drove around and found out the axle shaft is indeed turning with the wheel when the vehicle is moving and in 2wd. But I noticed that the axle would stop spinning for a second when I was doing a full turn like in a parking lot. And sometimes the axles did not seem to be turning at the speed the wheels was turning. I assume the axles spinning at highway speed is where the noise is coming from. Any ideas as to why the axle shafts are turning if everything checks out?
I did not get any replies from the expedition forum guys then I found Jim's post and it was the same issue.
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
Nothing on any pre-2011 resembles what you have on a 2017 Expedition. Not sure about the new Rangers.
Assuming the 2017 was still using the same basic system as earlier F-150s & Ex's, the front axles do turn all of the time. The vacuum actuator is actually on the differential and simply connects the differential to the already turning axles.
StanC
Va
I had that on my 1997 F150 but I believe the newer models do actually disconnect at the hub and the transfer case.
G8orFord
803
FL
4.0 SOHC S/C
The newest model I've looked at was a 2011, I think, so that's entirely possible.
Should be fairly easy to check, if there's a vacuum line at the hub, then it's vacuum actuated. If not, it's probably always connected.
snoranger
Professional money waster
ASE Certified Tech
13,660
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Last time I talked to him about it... he just leaves it in auto 4wd. It doesn’t make any noise with the the IWEs engaged.
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,848
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
Auto hubs usually fail and won't lock. Warning signs are when they start buzzing. The vacuum hubs are notoriously unreliable, and that is why Ford went live axle after only 2 or three years.
AJ
I don't think it was even that long. I'm sure it's in the Tech Library someplace but the pulse vacuum hubs came out in 1998 and as I recall Ford scrapped them and went to an always-live front axle halfway thought the 2000 model year.
Uncle Gump
Token Old Guy
13,486
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
So from 1998 to halfway through 2000... isn't that like... 2 or three years?
