Ford 7.5" to 8.8" swap
hntr45
2.3
Hey, so I think I know my answer to this, but I got a Ford 8.8" axle out of a 01 ranger 4x4. I wanted to swap it into a 1997 ford ranger 2wd. Is there any kind of modifications I need to do to the 8.8 or should it just bolt straight in? I'm pretty sure it should bolt in but I understand the 4x4 are lifted a little more than the 2wd. I wasn't sure if there was any differential angle differences to worry about.
scotts90ranger
4,368
Dayton Oregon
2.3 Turbo
The lift on the 4x4's is done with lift blocks in the rear, it's a direct bolt in, no modifications necessary
Mac
183
C. Wisconsin
2000
199
It would be wise to check what both pinion angles are supposed to be, minor differences are no problem. I have a chart from the shop manual that lists all the different possible pinion angles per body style/driveline.
Dave
