- Oct 17, 2019
- 3
- Longview Tx
- Ranger
- Engine Type
- 2.3 (4 Cylinder)
- 2WD / 4WD
- 2WD
- Tire Size
- 215 70 r16
I am tearing my motor down to do a head gasket on it so while it’s apart I’m doing a few upgrades just looking for a few HP and MPG I’m not building a race car here. So while the heads off I’ll magnaflux it, mill a couple thousands off and do a valve job on it. I’m also adding a high flow cat and cat back system and will probably gasket match my intake and exhaust. While I was removing the fan I noticed it’s in pretty rough shape... so I started researching fixed, clutch, flex, and electric fans. All have pros and cons and I discovered even the electric fan causes some parasitic loss and can also cause the engine to run too cool so I’m thinking a flex fan is the route I want to go. Best air flow lower high rpm resistance. Anyone else try this? All the Dynomax tests are on big block race motors and I’ve seen huge hp gains (3-5 wheel hp) I’m guessing our 4 cylinder is probably more hampered than a V8... any one tried it? What else have you done for MPG?
