exploder 8.8 to ranger question
dezert ranger
lake havasu city,az
have a 91 explorer 8,8 rear diff which is 3 " wider than stock ,how wide a tire can you run and still clear 4 " fiberglass bulge fenders,i have 32 x 11.5 s and 33 x 12.5s ,my rims are the mickey thompson simulated beadlocks that have some offset,dont want to try and mock up and reweld springpads unless i know it will work with wheel and tire combo,Thanks ,
Quasi242
January 2010 OTOTM Winner
Tucson, Arizona
4.0 SOHC
I have a Ford 9.75 axle (7" wider than the Ranger 8.8) installed on my truck. I am running 315/70 R17 (35"X12.0") tires on wheels with 4.5" backspace. The outer wall of my tires are nearly flush with my Fiberwerx 6" flair bedsides.
Since your axle is roughly 2" narrower per side than my axle, and your bedsides are also 2" narrower per side, it sounds like it should provide a similar fit. Wheel backspace and actual tire width will also play a part in the fit.
84projectFORD
Phoenix, AZ
should fit prefect in there. i had bed sides that were pulled 3"s and wheels with a 4.5 backspacing on 33x12.5 tires withe 8.8 and it was a little tighter than i liked but worked. for you they should fit nicely up in there
