- Aug 10, 2014
- 22
- Age
- 31
- Madison, IN
- Ford Ranger
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L
- 2WD / 4WD
- 2WD
- Tire Size
- 215/70R15
The week after next I'm pulling my 3.0 to do a long list of things:
-Oil Pan and Gasket
-Valve cover gaskets and grommets
-Exhaust manifolds (one busted stud, couldn't remove with the engine and manifold still in truck)
-Rear main seal (might as well while it's out)
I will have access to a hoist and engine stand.
Questions:
1. What are the lift points on the motor. I've not found a conclusive answer... I've not found any on the block (one tiny one on the upper intake though) and I thought I read that one could run a chain through the exhaust manifolds? Is there some special bracket tool thing I need to buy?
2. What size bolts will I need to buy to mate the stand to the engine?
3. Are there any other tidbits of advice I should know?
-Oil Pan and Gasket
Questions:
