driveshaft issues with susp lift ??
Boggin
48
just bought a 4" susp lift from The_Dealer, the axle drops are only 2.5" tuff countrys but the coils are 4"skyjackers, i was wondering if my front driveshaft will be long enough or if ill need it extended?
also my current rear driveshaft is the cv style, but i got a u joint style shaft that is exactly 3" longer, im wondering if that will bolt up in the rear with the susp lift added, or will i still need to shorten it?
thanks
t120r
Is the u-joint driveshaft a double cardan or just a single u-joint on each end?
Boggin
48
t120r
Well you need to measure pinion angles now. The output flange for the tcase needs to be exactly 180 degrees from the rearend yoke/flange. Picture a laser beam pointing out of each one.. The 2 beams would have to be parallel.
