Dome light stays on
Dwad17
Bishop, CA
I know there are a few threads on here about the dome light issues, but I have checked the usual culprits to no avail. I have a ‘95 ranger extra cab that I have recently changed the doors sensors and all the door ajar lights and chimes work, however the dome light still stays on. Any help would be appreciated.
8,372
Welcome to the forum
I have to ask so don't get mad..............is the dash light dimmer wheel turned OFF for dome light, it has a separate switch inside to activate dome light when wheel is turned all the way "up", you can feel a click on and then off when turning the wheel
I assume the "Door Ajar" light is OFF and only dome light is on, if thats the case then its not a GEM module issue
Above the gas pedal is Relay Box 1, it has a black cover over it, it faces towards parking brake pedal
Inside that box is the Interior light relay
The GEM Module activates this relay when a Door Switch is grounded, it also turns on "Door Ajar" light, at the same time
So no Door Ajar light means not a GEM issue
If there is a door ajar light then one of the door switch wires is shorted to ground somewhere or GEM is bad
Interior light relay is double pole so when not activated the dimmer wheel can send 12volts thru it to turn on dome light, this will also turn on the Cargo light on top back of cab if you have one(part of 3rd brake light)
Relay box 1 has a few relays inside and there is no good MAP for it because lay out changed yearly AND changed with Options added
After you take the cover off the relay 1 box see if it looks like this: http://ww2.justanswer.com/uploads/sasso1179/2010-07-12_195044_relays_one.gif
If you pull battery saver relay OR interior light relay out dome light should go off
Wiring diagram below
Dwad17
Bishop, CA
Thanks for the reply, and yes the dash dimmer/dome light switch is off (sorry forgot to mention that in in the original thread). I will try investigating the relay box that you mentioned.
Dwad17
Bishop, CA
So I attached a photo of the relay box that you mentioned and unfortunately it looks nothing like the diagram you have. I have no idea what any of those relays are for. Any thoughts?
Thanks
8,372
I do have another diagram that shows 8 relays, so like yours
This shows the 5 slots for each relay, so each 1-5 is one relay
As said there no exact diagram, that I have found, for each year and option package
The top 2 relays in your box should be the battery saver and interior lights
Dwad17
Bishop, CA
Please pardon my ignorance, but are you saying if I remove relay and the dome lights go off then the relay is bad and replacing it will solve my problem?
8,372
No, probably not, but you can swap it with another relay in that box(not battery saver relay) to see
With interior light relay unplugged you can test the 5 slots to see why the dome light is staying on
As shown on wiring diagram you can test each slot to see whats amiss
Slot 4 should only have 12v with dimmer wheel clicked on, if it shows 12v then dimmer wheel may be the problem
Slots 1 and 5 should have 12v all the time
Slot 2 should NOT be a ground, with doors closed, hard to test, lol
slot 3 is OUT to dome bulb, should read as a Ground all the time since bulb is grounded, if it has 12v see below
If dome light stays on with relay unplugged then the wire to the dome light is shorted to a 12volt wire somewhere
If you have MAP lights they have 12v all the time
Dwad17
Bishop, CA
Ok, thank you for all your help!
rubydist
865
Denver
Ford Ranger FX4
As I recall, opening the door turns on the dome light by connecting it to ground. So, if the light stays on with the door closed and if you know the door switch is good, it means that there is a short in that wire somewhere between the door switch and the light (assuming no "door ajar" indicator.)
8,372
The door switch ground goes to the GEM module(or SJB, 2004 and up)
When ground is seen it will then close the interior light relay to turn on Dome light, AND will also turn on "Door Ajar" light on dash
So if you have BOTH dome light and door ajar light then yes, could be shorted wire from switch or switch itself
1995 and up Rangers have no direct connection between door switch and dome light
