Different yolks. Can mine interchange?
Bear in the woods
94
Corinth Ms
Ford ranger XLT
2.9 in 90 , 4.0 in 99
30”
Swapping transmission. The one I got to go back in has different yolks On the transfer case. Can my yolks on my 99 interchange?
franklin2
1,775
Virginia
One has studs an the other has bolts?
Bear in the woods
94
Corinth Ms
Ford ranger XLT
30”
One is 2 1/2 inch bolt hole spacing. The other is 3
franklin2
1,775
Virginia
Same brand transfer cases? I don't know, I am just trying to get some more info for someone else who may know. I would think if they were both the same brand, you might have a chance. Like both are Borg Warner model ?????.
ericbphoto
Overlander in development
16,749
Wellford, SC
6"
Yolk won't work.
Use yoke instead
pjtoledo
3,006
Toledo Ohio
Fords
3.0 2.3
to further confuse the issue, same 1330 U joint ( 3.622) with 2 different flange patterns. 3" & 2-1/2"
both have the same cap size 1.062"
on one of my Rangers the transfer case end flange had both patterns.
