2.3L ('83-'97) Difference in Computers
RustRatz
22
Arkansas
Ford ranger
So I’ve got a 1993 2.3 in my 1992 ranger, and I’ve deleted the EGR. Will I have to go into the computer and tune it so it idles better? It still is reading for EGR stuff, but it’s deleted.
Also, I have an o2 sensor but can’t find the wiring to it. Will I need to either tune it so it doesn’t read it, or find the wiring and plug it in.
8,374
Computer needs the O2 sensor feed back, you need to find the round 4 wire connector, period
Or switch to a carburetor
Computer controlled fuel injection NEEDS sensors, several of them
Did the 1992 2.3l have an EGR system?
If not then no issues deleting EGR on the 1993 engine
EGR or no EGR is strictly a computer issue
Computers setup for EGR system can run a more agressive spark advance because less chance of pinging/knocking on 87 octane gasoline
If the 1992 did have EGR system then you will need to get a matching non-EGR computer or live with the CEL(check engine light) being on all the time
RustRatz
22
Arkansas
Ford ranger
original truck did have the egr system, so I’ll be on the lookout for the non egr computer or I’ll just unplug the CEL.
What do the connectors look like for the o2 sensors? I need to see if I have the wiring.
8,374
Google: 1992 Ford Ranger 2.3l O2 sensor
You can see its 4 wire connector, truck side will be same type, usually round often found between firewall and head on exhaust side
O2 sensors come with a 1 to 2ft wire attached, so the truck side harness wires are not that long
RustRatz
22
Arkansas
Ford ranger
Probably will just replace the o2 sensor then, because the o2 sensor itself, the wire on it is only about 6 inches long.
RustRatz
22
Arkansas
Ford ranger
Could I get a link on a good place to buy an o2 sensor? One that preferably has decent length wiring.
Blmpkn
Toilet enthusiast
6,422
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Buy Motorcraft or Bosch.
scotts90ranger
4,505
Dayton Oregon
2.3 Turbo
The O2 sensor for a '97 has at least 18" of wire, the connector is right behind the valve cover for some reason...
RustRatz
22
Arkansas
Ford ranger
I guess I’ll use one of them.
RustRatz
22
Arkansas
Ford ranger
Is that the upstream one or downstream one? Mine only has one o2 sensor total.
scotts90ranger
4,505
Dayton Oregon
2.3 Turbo
The long one is the upstream sensor, it's the only one I changed anyway (it's the most important anyway...)
