"without much difficulty"... I just did this, I put a '92 dash into one of my '88s as part of a 4.0 swap. Here's what I ran into
- the big cannon plug in '92 needs the correct size hole in the firewall (not there on '88)
- first gen steering column does not attach well to the second gen pedal bracket nor does it look right with a second gen dash
- second gen column does not bolt onto the firewall, the hole is too small, so you'll need to modify your '88 firewall. I opted to cut a whole section out of a newer cab and rivet it in place
- second gen pedal assembly (needed for second gen column and dash) does not fit the first gen firewall very well, needed extra reinforcement and some things cut off
- upper dash attachment screw locations are different - I cut these off a newer cab and welded them onto mine and had to bend some of them to fit
- lower dash attachment bolts - driver's side one is fine, passenger side one will need a tab added to the '88 pillar (doesn't exist on 1st gens)
- clutch slave cylinder push rod (if you have a manual) will be too short no matter what with second gen pedals. I had to make mine over an inch longer and adjustable
- HVAC plenums are similar, fortunately enough so that you use original under the hood and the '92 parts in the cab - the defrost section is different so the first gen HVAC plenum won't work
- Cab wiring - use whatever you have from the '92, the plugs are different, it's routed differently, etc
- additionally, using the '88 fuel level sender, your new '92 cluster will not read your fuel level correctly, so you'll need to modify your sending unit to fix that
- If you use the '92 dash harness, you will also be using the '92 headlight harness, which requires different plugs soldered on for your headlights
If you got through all that, you can probably guess by now that it's a pretty big project. I had roughly a solid month into mine between researching stuff, tracking down parts, etc
If you're doing this as part of a 4.0 swap... go for it... if you are doing it simply for appearance, I really, really would stress that it is a huge project.
