dana 28 axle shaft removal
stockfornow
4
eau claire wi
please correct me if i am wrong but if i read the tech libary right i can remove my left side axle shaft while leaving my sterring knuckle on.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Yes.
It comes out through the hole after removing the wheel spindle.
stockfornow
4
eau claire wi
thanks sounds easy enough to do myself. i was afraid that the knuckle had to come off.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
Be very careful of the spindle 'snout'. The threads are fine and damage easily. You will most likely have to pound it loose and this is dangerous. If you can avoid pounding at all that will be better. LMC Truck sells them still, but they are around $250 a piece.
It has 5 nuts (rather small) holing it on. Once those are loose it is sorta pressed into the knuckle. That is the part that's hard to break free.
