Crazy Idea For Lowering The Back Need Opinions
Status
Not open for further replies.
tylers4.0
Tn
2.3
ok so heres the deal i gotta friend who lowered the back of his ranger by flippin the leaf springs and it gave him a 7" drop not a flip kit just flippin the entire things upside down i he got hellacious camber and i dont want that so i thought wat if i flip them and then put 3 inch blocks to make it a 4" drop but i saw u can lift a ranger with blocks so its just an idea i need some help with thanks
Melt
Minocqua, WI
Mazda
2.5l
correct me if im wrong but this sounds like it would ride like ass
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
I'm guessing he hasn't driven it yet? If you flip the entire spring you've only got one leaf and it's inverted. You're upward suspension movement is going to be insane and it's not going to be able to go anywhere. essentially if you put a rubber bump stop on the frame, that'll be your "spring". It will ride so terrible I'm not sure I can write the words in this single post. Every crack and bubble in the road will be a near bone jarring impact.
if you're looking for 4" of drop stick with the SUA (axle flip). it's not a bad splurge, like $100 at the absolute most for new perches. You will thank yourself when your in the drivers seat and I will thank you as a fellow driver on the road.
one last thing, whats this about Camber? this is the rear we're talking about here right?
tylers4.0
Tn
2.3
haha yea i thought it would be a shitty idea thanks for the opinions tho
Loanranger
4
Puyallup, Wa
1972
Ford/
Fordzuki
2.9/2.3
This would technically work if you took the springpacks apart and reversed the order of the springs. But I agree, the spring under axle idea is much better, you could even find an explorer rear and kill three birds with one stone, beefier axle, disc brakes, and spring under.
ZMan
MTOTM Winner
406
Medina, Ohio
Ford Rangers
4/4, bagged
What I want to know is how the hell you get "hellacious camber" with a straight axle...
racsan
4,443
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
if you bent the axle, thats the only way i know to get a camber issue with a solid axle.
Dusty_Ranger
4
Salmo BC Canada
or for more drop use an explorer axle with stock blocks eh?
tylers4.0
Tn
2.3
yea it bent his axel ................. sorry you jump to conclusions so quick
koda6966
61
The green part of NY.
yea it bent his axel ..............sorry you jump to conclusions so quick
You.
Can't.
Have.
Camber.
On.
A.
Strait.
Axel.
I'm hoisting the flag.
:bsflag:
mhughes165
9
302
there is no way to get camber on a solid axle, there is no way that what he did would cause enough stress on the axle to bend it, will it ride like total ass, no questions asked there, ittll ride like ur on bricks for springs, the only way to have hellacious camber is if the wheel bearings on both sides of the axles were non existent.....if u want that much of a drop just do spring under and a block, thats a 5" drop and itll still ride decent
tylers4.0
Tn
2.3
i appreciate it but it "messed" his "stuff" up and i guess i used hellacious a litte much at least a couple people aint total .... on here
koda6966
61
This isn't the garage. Watch your language. I've mildly censored the above quotes. Don't start swearing and throwing a fit because you have no clue about camber and solid axles. Which can't happen.
I vote you get banned.
mhughes165
9
302
i appreciate it but it fucked his shit up and i guess i used hellacious a litte much at least a couple people aint total dicks on here
what u arent understanding....is short of him DUNE JUMPING, there is nothing that can cause what ur claimin, its not at all possible,
Status
