Coil spacers
nb11
10
South Georgia
2.3l
Do they go above or below the spring? I'm looking to install some on my 2003 ranger. I think I'm gonna make some like those shown in the tech library, out of washers, and I'm already planning to get longer shocks. Any other tips? Thanks!
straycat
77
02 06 and 2012
Jeeps
The ones I have seen go under or in between the coils. I think the ones that go under are a lot safer then the ones that fit in between the coils. I would just a taller coil. I am not a fan of spacers. Some of our members here do use them and as far as I know they never had a problem with them (the ones that mount under the coil).
lil_Blue_Ford
6,131
Butler, PA, USSA
4.9L
Those are not going to work for your truck. Spring spacers ONLY work with the 1997 and older trucks.
IF you have a torsion bar front suspension (4x4 and some 2wd models), you can crank them to get a couple inches but thats it unless you want to spend some money to rebuild the suspension.
If you have coils and A-arms (2wd) your options are limited to using lift spindles or changing the front suspension out to something else.
lil_Blue_Ford
6,131
Butler, PA, USSA
4.9L
Here is a link to Daystar install instructions on spacers. Maybe this will help.
http://www.daystarweb.com/attachments/instructions/kg/p10476.pdf
Straycat, there are really no good spacer options for newer Rangers. Pretty much all that is available is cheesy stuff like the "twist-in" spring spacers (ie - dangerous junk) or a spacer that makes up for a winding of the coil on top or bottom (which means that less of the real coil engages the seat for it, thus risking the coil popping out).
All of the Daystar stuff I was able to find is designed to replace the top coil cup for a strut system, not the A-arm coil setup that Rangers use. The only other ones are for the '97 and older suspensions.
straycat
77
02 06 and 2012
Jeeps
I just gave him a link to show how spacers are installed. I know people who have used spacers on their coil sprung suspensions and have never had a problem as long as they were not the twist in type. He never said if he had a 4wd or 2wd. and I presume since he mentioned coils that he had a coil suspension. He can buy lift coils and just go with that for a better safer ride.
Ranger Sport Honduras
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
Fortune Favors the Brave
coils wont pop out using the 98+ coil spacers, lots of people use them
just make sure they are meant for a 98+ truck.
and they usually go below the spring
The_Dealer
10
Macon, GA
Duh!
make sure u buy an extra pair of insulators to keep them from making noises. put one btween the coil and spacer, and another btween the spacer and frame...i would get 2" coils they ride alot better and dont make noise. spacers will increase the spring rate on the 98+ rigs...i had some before i went with some custom deaver coils and btf uniball uppers on my 00
nb11
10
South Georgia
2.3l
Sorry I should have been more specific. It's a 2wd and I do have the a-arm setup. I wanted to avoid something expensive like spindles, and I saw on ranger sport honduras' build thread how he used a sort of coil spacer, and I believe he has a 2003 with the sale suspension. I've considered lift springs, but they cost a little more than some big washers lol.
nb11
10
South Georgia
2.3l
Just kidding, just now read that his is a '99. Don't know where 2003 came from?
lil_Blue_Ford
6,131
Butler, PA, USSA
4.9L
The washer trick only works on 97 and older Rangers.
