Changing timing belt. What seals do I need?
Bartmuley
Jason00!
Ford ranger
I’m changing my timing belt, I’m confused about which seals I should change while I’m in there?
Is it crankshaft, camshaft and front Auxiliary seal?
racsan
4,485
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
no seals need to be replaced when doing a timing belt, I would recommend putting on a new water pump & thermostat while your doing this project.
8,372
+1 ^^^
If there are no oil leaks in the front then just replace the belt
You can replace the Crank sensor but its a pain to run the wires in a 1994(1989-1994) and if its working then I would just leave it alone
There is a Belt guide(large keyed washer) on the front of the crank gear, that you may need to remove to get the old belt off(assuming its not broken, lol) and new belt in
You have to remove crank sensor and its bracket to do that, and don't forget to put it back on, the belt guide, or belt WILL "walk off" the other gears
There is a tool to realign the crank sensor, but you can usually use a feeler gauge or just common sense to realign it so it doesn't rub/touch the Vane on the back of the hub assembly as it rotates
fastpakr
2,840
Roanoke, VA
Just to confirm, this is a '94 2.3? I'll move it to the correct engine section if so.
Bartmuley
Jason00!
Ford ranger
I know they don’t have to be changed but I’ve been told I might as well while I’m doing it.
I just am not sure the names of the ones I need. Crankshaft, camshaft and is the third “auxiliary shaft oil seal”?
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Yes the 3rd one is the auxiliary shaft seal. It's the center gear that drives the oil pump.
Bill masoner
Benton ar
Ford ranger
Hey I'm bill james bj for short...how does this tensioner work guys?
8,372
Welcome to TRS Bill :)
You should start your own thread, just easier for all of us and you
General forum etiquette, is that you don't post in someone else's thread unless you are answering their question, when there are multiple questions from different people in one thread it gets very hard to know what answers go with what question
And to answer your question, the 2.3l tensioner works great, lol, joking
Anyway, Google: 1993 ford ranger 2.3l belt tensioner install
There are a few videos on how to remove it and replace it
To start your own thread, pick a sub-forum, General Discussions is fine, here: https://www.therangerstation.com/forums/index.php?forums/general-discussions.2/
Just above all the posts in this sub-forum is a blank line with "Thread Title" in light grey, click on it
Enter the title you want, like "2.3l tensioner question"
Then add the question in the "message" part
Then "Post Thread"
It can take a few minutes for it to show up because you are a new member, posts need to be checked before becoming public so we don't get roBot posts or other inappropriate posts showing up
Bartmuley
Jason00!
Ford ranger
there are videos on YouTube that explain it better than I could, but it’s not complicated.
if you can’t find anything that helps you let me know and I’ll see if I can find some of the links videos that I watched.
scotts90ranger
4,416
Dayton Oregon
2.3 Turbo
The tensioner is simple to use, the pivot bolt and the other bolt both hold it tight, loosen both and it'll flop over to it's extreme, stick a pry bar or claw hammer (that's what I've been using lately) between the spring and the pulley and pry it back to the other extreme or as far as you can get it then tighten just the short bolt. Now put the timing belt on and line up the marks, then loosen the small bolt. Now turn the crank two revolutions until the marks line up again to verify everything is in time now tighten both bolts then reassemble.
