Center console latch on my '94 Ranger is broken. Any cheap/easy fixes?
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,708
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I thought I saw a replacement plastic insert listed on an online site the other day. CarID I think? It wasn't exactly cheap though.
Bgunner
1,089
Western Mass.
Ford/Ranger XLT
225/70/R15
Bgunner
1,089
Western Mass.
Ford/Ranger XLT
225/70/R15
There are 4 screws in the corners under the felt/rugging on the arm rest lid. This is where you have a map slot in the lid. Remove the map holder.
Trim any left over plastic to give the aluminum a snug fit and glue in place don't use quick set glue because you want to be able to adjust the placement once back together.
put the map holder plastic back on and check for fitment with the latch. let glue dry.
then your done.
Colin
182
ON Canada
Mazda
You can also epoxy a screw up side down so the mechanism grabs head. Or carve a new hook out of wood and glue that in. I did the screw with my old truck, and later I made a new lid out of plywood and put the original foam and fabric on it
fubie
USA
Thanks for the help, folks! Got it fixed.
