Center console latch on my '94 Ranger is broken. Any cheap/easy fixes?
Rock Auto 5% Discount Code: 4FF3E9EEA14805 Expires: October 1st, 2020
sgtsandman
Aircraft Tank Diver
Forum Moderator
2,021
Aliquippa, PA
2011 & 2019
Ford XLT & FX4
4.0 SOHC & 2.3 Ecoboost
31X10.5R15 & 265/65R17
I sniff fuel for a living. Don't judge me!
I thought I saw a replacement plastic insert listed on an online site the other day. CarID I think? It wasn't exactly cheap though.
Bgunner
Well-known member
432
Western Mass.
Ford/Ranger XLT
215/75/R14
Bgunner
Well-known member
432
Western Mass.
Ford/Ranger XLT
215/75/R14
There are 4 screws in the corners under the felt/rugging on the arm rest lid. This is where you have a map slot in the lid. Remove the map holder.
Trim any left over plastic to give the aluminum a snug fit and glue in place don't use quick set glue because you want to be able to adjust the placement once back together.
put the map holder plastic back on and check for fitment with the latch. let glue dry.
then your done.
Colin
Well-known member
118
ON Canada
Mazda
You can also epoxy a screw up side down so the mechanism grabs head. Or carve a new hook out of wood and glue that in. I did the screw with my old truck, and later I made a new lid out of plywood and put the original foam and fabric on it
fubie
New member
USA
Thanks for the help, folks! Got it fixed.
