can you install a camshaft while the motor is in the vehicle?
stamina
34
Wilmington, NC
4” suspension
265/75/r16
built her in a storage unit
i have a 1990 ranger standard cab with a 4.0, by removing the grille, radiator, fan, and condenser is it possible to install a cam while the motor is in the vehicle?
racsan
4,441
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
You should be able to, I did that with a ‘77 305 nova. The only thing im unsure of is weather there is a strip of metal in the middle of the core support, you could always cut it out then weld or pop rivit it back in. I think the cam is higher than the front bumper, so no need to remove it.
rhekman
35
Lakes Country, Minnesota, USA
2"
Are you asking about leaving the intake/heads in place on the motor? I don't think the 4.0 hydraulic roller lifters will fall out of the bottom of their bores, but their preload might give you trouble re-installing a new cam. They don't have a retention mechanism like a GM LS.
I've only ever replaced cams in motors out on a stand. In the engine bay, you might need to remove the valve covers and loosen the rocker shafts to get a new camshaft in through the core support.
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
I don't see why it can't be done. as long as you get the front of the truck's body clear. you will need a straight unobstructed line into the cam's bearings. going in and out.
(rhekman) yes all the heads and lifters will need to be taken off the engine, as it would be 100% impossible to return the cam shaft into place, let along get the old one out.
cheers
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
Just out of curiosity, are you swapping in a bigger aftermarket cam or just replacing the stock cam?
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
If the 4.0 is like a 2.9- and I think it is- the lifters won't come out with the heads in place. The little extra work to pull the engine out where you can work on it comfortably is worth doing.
Angie
368
92 & 83 project
4.0L 302
"the lifters won't come out with the heads in place. "
Is there an engine out there where the lifters will come out with the heads intact on the block?
gw33gp
Ham Radio Operator
536
Costa Mesa, CA
4.0 SOHC
33"
I have an engine that I can remove the lifters with only taking the valve cover and rockers off. It has a side cover plate that gives access to the lifters. However, that is not possible with any Ranger engine I am aware of.
fastpakr
2,832
Roanoke, VA
Sure, a 302 is one example.
Angie
368
92 & 83 project
4.0L 302
interesting. next engine i pull apart i am going to try and see how easy it is to replace a lifter with heads on. Never thought of looking into it before. just assumed for ease to take heads off.
cheers
superj
2,577
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
If you don't have clearance because of something in the front, you can unbolt the motor mounts from the frame and lift the front of the motor with a floor jack, too
