2.3L ('02-'11) Camshaft position sensor location?
barliebmj
New Jersey
where is this sensor located? My truck misfires and carbon fouls plugs, have replaced O2, MAP, MAF, TPS, Cylinder head temp sensor, engine blows grey smoke too rich. CEL always says lean code. Anyone got a picture of this thing in the truck?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Very back passengers side of the valve cover.
Here-ish...
But it does not sound like a cam position sensor problem. Sounds more like a large vacuum leak.
8,370
+1 ^^^^
Welcome to TRS :)
"Lean" code is often confused by people thinking its Fuel related, it is "sort of" but not really
Computer calculates air/fuel mix based on engine RPMs, it "knows" its running a 2.3 liter engine so its a pretty simple calculation to get how many Liters of air are coming in at say 2,500rpms, just math
14.7:1 Air/fuel mix the WEIGHT based
14.7 pounds of air to 1 pound of gasoline
14.7 grams of air to 1 gram of gasoline
Again just math
Gasoline's weight doesn't change much with temperature
The big variables are Air TEMP and Air WEIGHT
Cold air is heavier than warm air, "hot air rises", because its LIGHTER that cooler air, so there is an IAT or ACT air temp sensor
Air is lighter(less dense) at 5,000ft elevation than it is a Sea Level, this is what the MAF sensor is for, it measures air density, the WEIGHT of the incoming air
Computer calculates the air/fuel ratio by RPM then off-sets that calculation based on air temp and air weight
This is called 0 STFT(short term fuel trim), and this is the OPEN TIME calculated for each fuel injector
Computer "knows" the size of the injectors, and since there is no fuel pressure sensor, computer assume 55psi(1998 and up Rangers)
Computer opens each injector and THEN..........it watches O2 sensor for feed back on STFT 0
O2 sensors can ONLY see Oxygen, not fuel
Too much oxygen in exhaust is "lean"
Too little oxygen in exhaust is "rich"
If "lean" the computer changes STFT 0 to STFT +2%, so it opens injectors 2% longer than it calculated, if O2 still shows "lean" then STFT +4%............ect, if it gets to STFT +15% or higher it will set a "lean" code
STFT -15% would set "rich" code
All this happens in less than 2 seconds, so engine was never running "lean"
If all the air is not passing thru the MAF sensor then computer calculations would be off, that's why Vacuum leaks can cause "lean" codes
MAF only samples 10% of the incoming air so small difference at MAF is a TIMES 10 difference at computer
Your issue reads like a "false lean"
Computer is seeing too much oxygen in exhaust and is adding more fuel, STFT +15%, but its "false" so engine is actually running Richer than it should
Misfires cause false leans because when a cylinder doesn't fire no oxygen is used up and its all dumped into exhaust manifold so O2 sees high oxygen, false lean.............computer adds more fuel
Exhaust manifolds SUCK IN AIR, so an exhaust leak at the engine gasket pulls in air and O2 sees extra oxygen, false lean........computer adds more fuel
Old O2 sensors, these last 150k miles or 12 years, then chemicals are used up, they show leaner and leaner oxygen levels as they age, so MPG gets lower and lower, worth while changing these at 100k miles
Loose O2 sensor, sucks in air around the threads, false lean
Clogged exhaust, prevents oxygen/exhaust from exiting, also limits RPM/power
Your Misfires are the likely issue for the false lean
I would do a compression test on each cylinder just to take that off the table, because if it is a compression issue you will just be wasting time(and money) looking for spark/fuel issues
Leaking injector, yes you would think that would cause "rich" code, but no, it causes Misfires so false lean
The smoke can be the unburned fuel being burned up by the Cat(s)
barliebmj
New Jersey
There are no vacuum leaks, no exhaust leaks, good compression. Sometimes it will idle fine, most of the time it idles very rough and only runs on 3 cylinders, and has no power unless you go wide open throttle, then the miss firing cylinders clear out and then it starts again as soon as you let up on the throttle.
barliebmj
New Jersey
I sprayed engine start fluid around all the vacuum lines and connection, intake manifold, exhaust manifold has no leaks. No vacuum leaks. Changed the evap purge valve, O2 sensor, MAF, MAP cylinder head temp sensor, coil pack, plugs and wires. Has P0128 code all the time. Going for the thermostat next. Also has new fuel pump, filter. Alway misfires on no4 cylinder, unplug plug wire and still idles the same. Bad fuel injectors? Guage shows 60psi at fuel rail with engine running.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Are there any codes other than lean? Are there any cracks on you air intake system? Lean conditions are from the metered air side, i.e. vacuum leaks
It could be a bad injector. Get hold of a FSM (factory service manual) and start testing and diagnosing items rather than throwing parts at it.
barliebmj
New Jersey
P0128 thermostat. This misfire problem started all of a sudden for no reason. Truck was running fine then started misfiring. I suspect the valve guide seals are shot, or the fuel injectors on cyls 3 and 4. 4 seems to be the biggest culprit.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Code P0128 - Coolant Temperature Below Thermostat Regulating Temperature. The OBDII trouble code P0128 - Coolant Temperature Below Thermostat Regulating Temperature means that the engine does not reach expected temperature after running for sufficient time, or in other words, takes too long to warm up.
Fix that and it will probably fix the misfire. There are 2 temp sensors for the ECM, you've replace one already. It could be the t-stat too.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
You've replaced so much stuff its now impossible to know if you've just not got lucky enough yet, or you could have one or more bad new parts. Most of the stuff you replaced are not wear items and should only be replaced when tested and verified faulty. You need to stop throwing parts at it and do diagnostics.
You say compression is good but what are the numbers and did you do a wet/dry test?
Run a series of vacuum tests. You can check for exhaust problems, valve problems, and some other things with a 10 dollar vacuum guage.
The spray test for vacuum leaks is not foolproof, especially on a duratec since their are spots on the bottom of the engine where vacuum leaks can happen. Like the oil separator. The EGR valve is also almost impossible to test with starting fluid because of its placement and by design they leak internally. A smoke test is much better but you can also run a vacuum guage and compare with the baro/map sensor readings to get an idea if it's pulling the correct amount of vacuum at idle.
Fuel trim data is also a good way to check for a vacuum leak. High trims at idle that drop quickly when the engine is put under load is usually a good indication of a vacuum leak.
barliebmj
New Jersey
THERE IS ONLY 1 VACUUM LINE ON THE BOTTOM OF THE ENGINE, IT IS FOR THE PCV VALVE WHICH IS NEW. I STARTED THE ENGINE WITH IT OUT OF THE OIL SEPARATOR AND IT HAS VACCUM AT IDLE. Here is something strange. The engine runs on all cylinders when it is floored, but runs on 2 or 3 cylinders at part throttle cruise and then it shakes horribly. Does not have VVT or IMRC engine.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
