ByPASS hose on my 1989 Bronco II
ChefKeith
5
Arizona
Ford Bronco II
does anyone have a picture of it installed on the motor? Like, where the heck is it?
KP
8,370
"By-pass hose"?
For coolant?
For air?
ChefKeith
5
Arizona
Ford Bronco II
on the motor for coolant i guess, little short 5/8 hose?
8,370
There are two heater hoses
One runs from lower intake by thermostat to firewall heater hose connection
Other runs from water pump to firewall for other heater hose connection
Heater core has no assigned direction of flow, so hose can be hooked up either way at the firewall
Pictures here of B2 engine bay: https://www.broncocorral.com/tech_library/ford-2-9l-v-6-engines-1986-1990/
ChefKeith
5
Arizona
Ford Bronco II
not a heater hose, ByPass hose about 8 in long, formed, 5/8 2 bends
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
On my 2.9, the only hoses that have collant in them are the two hoses from the rad and two going to heater corer. Thats it.
8,370
Upper and lower radiator hoses and 2 heater hoses are all I remember on my 2.9l
Could it be for the PCV Valve or Breather hose, air hoses
ChefKeith
5
Arizona
Ford Bronco II
go to NAPA and look up part number 7713, unfortunately no one at NAPA knows there butt from buttermilk these days.
8,370
Looks like a PCV Valve hose
ford4wd08
510
Alcoa, TN
2.8 V6
I know the 2.8 has a bypass hose when the thermostat is located in the timing cover like mine.
The cold coolant loop with thermostat closed is kinda weird on the 2.8. I'm not sure any of that will apply to the 2.9.
8,370
Well after the upper and lower rad hoses and the 2 heater hoses are hooked up, fill with water.........................
You will see soon enough if a coolant hose is missing :)
85_Ranger4x4
17,866
SW Iowa
My 2.8 had the thermostat up high and it had a bypass hose too.
