Northidahotrailblazer
- Feb 21, 2012
- 457
- Northern Idaho
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- Solid Axle Swap 4x4
- Total Lift
- 8 inches
- Tire Size
- 37"
Any one see this when adding LED lights? I'm getting 5 volts to the brake lights. Enough to make them stay on slightly. With a regular bulb you cant see it. I unplugged the brake light switch and no change. When I unplug the turn signal switch the lights go off. I swapped the switch with an used one, and now the LEDs are even darker and i'm getting less than like around 2 volts. I ordered a new switch but I don't know where it could get stray voltage from other than a shorted wire right? I unplugged both the flashers and my brake switch and they stay on. I'm going to try a new turn signal switch and try that first.
