Boss 302 Swap Advise
EBranger96
San Jose
Hi guys I got a 1990 automatic 2wd and want to swap a 302 into it as well as a manual transmission (I’m a novice to this but have lots of experienced friends to help). Do you think it would be easier to purchase a running engine + transmission separately and look for the accompanying accessories or should I look for a 302 older mustang donor car? If I get a donor car, what are some good places to look to ensure I get a good vehicle? Would I need custom trans mounts and drive shaft adapters?
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
Hi, welcome.
First bit of advise is to read over all these pages threads about what troubles and expenses people have encountered. Asking a loaded question as what is easiest? There is no easy to this, depends on skill level and how deep you want to go into the rabbit hole, and how much money you have for a budget.
As for vehicle depends on what your expectations are for your build ... EFI or carb is the first question you need to answer.
If efi, go for a explorer V8 as you get all the wiring bits and bobs with it (hopefully)... any donor car will get you 1 of 2 things ... a good engine or someone's money pit.
Ask all the questions you need answered, but there are many very informative pages in here to read first.
cheers and good luck
EBranger96
San Jose
HI Angie,
Thank you for the response. I was thinking of going for EFI and pulling the comp and wiring from the donor. I was initially thinking explorer V8 but they are surprisingly hard to find in my area - the early to mid 90s mustang gts are really easy to find. I guess easy is the wrong term, I was just wondering if having a donor car simplified the process since you have the accessories already instead of searching for them somewhere else. I'll keep looking for some good pages here on mustang 5.0L swaps
Angie
368
92 & 83 project
4.0L 302
I always forget to mention the tech pages....
this is some great info to browse through.
cheers
19Walt93
4,484
Canaan,NH
351
3"
235/55R16
Boss 302's were only built in 69 and 70,are worth mega dollars now, and would be a poor choice for a street driven truck because their huge valves make them doggy at low revs. I'd use a 302 new enough to have a roller cam so you don't have to use a zinc additive and it opens up a lot more cam choices. A mustang engine with EFI will be a roller cam, as will an Explorer. 1986 Mustangs used unique pistons and heads, they ran fine but it makes modification more complicated. T Birds and Explorers also have shorter FEAD (front end accessory drive) systems to make fitting them in a Ranger easier. I found that out after hollowing out my core support and putting the radiator inside it to clear my Mustang pulleys and brackets.
EBranger96
San Jose
Hey Walt,
yep sorry bout that I meant the standard 5.0 302s. That’s good info about the shorter front end accessories - I wish I could use an explorer but the options are just so limited for me here unfortunately. And thanks Angie, i’ll check out those links
Angie
368
92 & 83 project
4.0L 302
EB, I just noticed your location. Are you in California? if so .. this might change all your options.
EBranger96
San Jose
Angie,
Yep i’m in California, what options do I have?
Angie
368
92 & 83 project
4.0L 302
You are limited to what engine(s) specs and years you are allowed to use. I am not 100% sure the regulations for you state, however, from what other people have talked about in other builds, they have to follow guidelines for smog and stuff.
I am sure someone who knows more will chime in as I am not in the know.
cheers
19Walt93
4,484
Canaan,NH
351
3"
235/55R16
Angie,
That's a good point, do the research first before doing a lot of work and spending money. NH does OBD II emissions testing on 96 and newer vehicles, that's why I used a 93 for my 351 swap. I'm sure California has a lot more regulations. Good luck.
